18 months ago at 130109
High speed HC 58 CO .15
Idle HC 62 CO 62
Last week at 134055
High speed HC 311 CO .85
Idle HC 470 CO .5
After replacing O2 sensor (which tested ok) and finding the bad plug wire (slight stumble at idle no miss under load)
High Speed HC 145 CO .65 PASS
Idle HC 266 CO .21 FAIL
The car sat for almost the entire year and what little I did drive was 90% freeway. Yesterday I replaced the spark plugs (which were brown and #5 showed signs of blow-by) and reset the timing from 14 to 10 (yes the diag connector was in place).
The car idles smooth as silk, accelerates with 8lbs of boost with no problem, there are no vacuum leaks and all management control parts are in place and functioning.
I did add some injector cleaner that I had laying around could this be a contributing factor? It was some cheap stuff from Checker Auto Parts.
Could the Cat Converter be failed? How would I check it's efficiency?
Idle HC 62 CO 62
Last week at 134055
Idle HC 470 CO .5
