Well i have an 89 supra turbo my problem is the odometer,speedometer,and water temp doesn't work.I am pretty sure the temp sender is bad and well my speedometer cable might be messed up not sure(the cable is chewed up).But as far as odometer how would i go about fixing it?I took out the gauge panel and everything is hooked up i also checked my fuses and everything is fine.So could it be that the gauge panel is faulty?What can you guys suggest for me?thanks
