Here's kind of an odd question
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
This question is pretaining to the wiring pins and connectors between the early harnesses and the late harnesses....
The question is, does anyone know whether or not the wire pins for and early harness fit the the same connector from a late harness?
an example if your not following would be if I were to extract the pin for say the B1 connector of an early harness, would that pin fit the B1 connector of the lat harness.... (i.e. is the pin itself bychance the same)
I know that I could just go test it for myself and see, but its kinda a hassle right now so I figured I'd ask to see if anyone might already know cause I wont be able to get around to trying it until this weekend.
