I've searched around some got some idea's as to why my car will not start. Over the weekend I put in 550 injectors and a lex maf, I have a BIC DDP with a full 3 inch exhaust, WB O2. Turn the car over spit and spudder but wouldn't fire right up. A few times it would start but it wasn't running on all 6 cylinders, I gave it a little bit of gas and had it running at 2500 rpm but let off and it would die immedatietly. Will these cars run with a bad AFM or just flat out won't run? I'm wondering seeing i had the TB off that I may have screwed up the wiring harness for the TPS, do these problems sound like that could possibly be a cause? The lower seals on the fuel injectors being broken cause sumtin like this? Cause I found I had three that pretty much fell apart after moving the fuel rail around some. Already ordered new ones from Toyota.
