Help
_Darth_vaider_
California
Guys I ran into a decent problem my light switch stopped locking so my cars high beams are on most if the time (holding it back while driving and shifting I is not so easy hah)
stopped locking?
You can pull the cap off the end of the stock. remove the white clip by pulled the 2 tabs apart and pull the rotating part off hte stock. bend the tabs out and re install.
_Darth_vaider_
California
No the stick doesn't lock back not the rotating part when I turn the lights on it is automatically on high beams.then you pull it back and it becomes low beams
You dont need one. Just leave the nut on a couple threads and pull side to side and top to bottom like checking for tie rods and wheels bearings.
