help with brakes, hard pedal.
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
ok i just finish a jdm 7mgte swap and i have no power brakes, Brake pedal is hard as rock.
I check the vacuum lines and even replaced the vacuum line that runs from the intake mani to the brake booster, no difference.
The brakes on this car worked perfectly be4 the swap, car has only been sitting for 2 weeks. Granted its been below freezing temps the whole time but still i doubt all 4 calipers are frozen?
So what do you guys think? a vacuum problem? or replace brake booster or master cylinder?
Im thinking maybe if i re_bleed the brakes?
Idk i never had this problem on my last 7m swap that i did.
what could all of the possibilities be that i lost my power brakes.?
cuel
1,536
Baytown, Texas
Isn't there a one way valve in the vacuum line from the intake to the booster? If you have it backwards, could be your problem.
cuel
1,536
Baytown, Texas
I'd check for vacuum leaks, first...
I'm not really sure if that's a valve, or just a union up above the booster.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
I was thinking the same thing about the check valve. Your brake booster (big black thing behind the master cyl.) could have a leak.
queenskid926
Jul 27, 2007
1,112
New York City
fixed the check valve was clogged, swap in another one and issue fixed. And yea it was clogged cause after i swaped in the other one i tried to run it both ways and it didnt work.
thanks cuel for your help and guiding me in the right direction.
