Help with AEM EMS on a 1.5jz
JZ_n_It
33
Norfolk, VA
ok set up is a 1.5jz with a build that i would like to rate in between stock and mildly built. the turbo is a 60-1 t4. nothing special really. and a GM 3 bar map sensor. oh and injectors are usdm 2jz injectors
so here goes. I can do mechanical, i can do wiring. but i fail at trying to make my ECU work. Its a 30-1100 box. my laptop coms up with the box and crank and cam angle sensors are syncing when I'm trying to get it to turn over. what am i doing wrong? if anyone has a base map to load that is known to work for initial start up that would help too. cus right now im just running the base calibration for 1100 and 3bar map.
