I was wondering what can I expect from my 1jz with the folowing mods. Full 3.5 turbo back exhaust, hard ic pipes, bov, filter, and 12 lbs of boost? Also wat would be the best way to tune it? Map ecu, emanage, safc? I have a wide band and boost gauge. I'm leaning towards a map ecu because you can control timing and boost with it also it seems easier to tune than a safc (wich I've had some experience with). Or would a electronic boost controller be better with a safc? Will the car run decent with the stock ecu and a boost controller and that's it? I'm still waiting on my parts from driftmotion so I have time to figure this stuff out
Thanks Corey
Thanks Corey
