help stumble 7mgte!!!
ccguy
53
az
hey jetdick, i have NEVER seen you post ANYTHING positive on this forum.
i have fixed everything wrong that i have found. this is the only problem there is with this swap. everything else is good and trail ready. double and triple checking all wiring, cps, tps, afm, ect sensor, knock sensors and wiring, ecu, ignitor, etc.....
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
jetdick? Never? Perhaps that's why you're unable to repair such a simple problem. That and your atrocious diagnostic approach based on no understanding of how the system actually works. Anyway, I was just going by your previous posts about fuel pressure, running rich, bad idle, etc. If you've fixed all that the rest should be a cake walk...
ccguy
53
az
simple problem. funny stuff there.
you sound like one of those kind of guys who belittles people online to make up for being bullied in high school or other short comings.
bad idle has never been an issue or fuel pressure.
so after a year of daily searching, fsm reading, tech bulletin reading, contacting others with similar problems and working on the vehicle i can attest that it is not just a "cake walk" or maybe i just dont get it....
i have the is300 coils on there now, a OE toyota fuel pump running at 32 psi at idle and 40 at fpr vsv fuel up.
hard to diagnose when everything checks out to pass specifications. the only noticeable action at all is the unplugging of the hac. motor runs great up to ~2600 rpm then the problem starts.
here is the updated (clearer) explanation:
1987 7mgte rebuilt motor, head milled, oe hg, arp studs torqued to 80 ft lbs and were retorqued after heat sequences, 440 injectors, stock 7mgte afm housing and meter, 3" doenpipe/full exhaust, water to air intercooler, ign timing at 10 deg. wiring to the tps, afm, ect, hac have all been rewired with new wire and to speck on the tsrm for a 1987 7mgte ( http://www.turboninjas.com/mk3supra/1987/1987_Mk3_TEWD.pdf )( i thought the original wiring was to blame), cps is installed correctly and triple checked.
~6300 ft elevation
engine swapped into 1980 toyota 4x4
-engine starts and idles great at ~800ish rpms. fuel pressure at 32psi at idle and fuel up vsv line hooked up to the FPR and fuel pressure changes to 40 psi when throttle applied.
-ign timing with jumper in place it is 10 deg btdc at idle and at operating temp.
-at idle -17 vacuum
-PROBLEM: with light throttle (very slowly applying throttle) revs smoothly up to 2800 rpm. once 2800 rpm has been reached if throttle is applied over that the motor will not go past the 2800 rpm and bog down to 2000rpm and act like/sound if you were to exhale all of the air out of your lungs and continued to blow more out but cant. while doing this it will make a stumbling noise and some popping noises, also you can hear the turbo spooling through the exhaust and occasionally a backfire pop through the air filter if the throttle is WOT.
this hesitation stays from the 2800 rpm amount of throttle through WOT. up to 2800 rpm the vacuum is -15 or so and when hesitating at WOT it will go to 0. once the hesitation starts it continues through WOT and when it is hesitating the more throttle from the begining at 2800rpm to WOT the vacuum gauge acts as if it is operating from -15 to 0 on a cable attached to the throttle.
if the throttle is revved up like vroom vroom vroom vroom sometimes it will overcome the problem and rev up to redline like a normal motor.
this happens at idle and even worse during driving.
when the hesitation starts at while driving it bucks violently and fells like some suspension is going to break a ring gear, u joint, tranny etc...
during driving if you get past the hesitation and are at cruising speed (under 2800 rpm) if you hold the throttle steady and the speed catches up to how far the throttle is open it will feel like a switch, it is off power and will accel back up to where the throttle is depressed (the off power feels like when you would hit the cancel switch while on cruise control).
if i open the throttle enough to get over the 2800 rpm hesitation the truck will act like i am flooring it (WOT) even if the throttle is barely cracked and accelerate like crazy until it catches up with the speed and then "power off".
here is the link to my youtube with the videos
http://www.youtube.com/user/cctool/videos?view=0&flow=grid
what i have found through testing.
***with the tps (only) unplugged:
-no dash cel light on.
-with jumper in and engine off and key on cel code 51 illuminates.
-slightly higher idle
-i can rev it up over the stumble by working the throttle open closed open closed etc...to redline
-can rev slowly up to 2800 rpm then above that to WOT it will bog down and drop to 2000 rpm while doing this it will make a stumbling noise and some popping noises and occasionally a backfire pop through the air filter if the throttle is WOT while not under load in driveway.
-reset ecu and no cel stored
***with afm (only) unplugged:
-dash cel light as soon as motor is started
-key on engine off cel 24 and 31
- i can NOT rev it up over the stumble by working the throttle open closed open closed etc...
-will not rev past the 2800 rpm at all.
***tps and afm unpluged:
-key on engine off cel 24, 31, 51 codes
***unplugged hac (only):
-no dash cel light
-key on engine off cel 32
- i can rev it up over the stumble by just giving it more throttle
-will rev past the 2800 rpm. and seems to rev up past the hesitation a lot easier than with it plugged in.
-it does not hang up like when it I is plugged in
***with ect (only) unplugged:
-key on engine off cel 22
- i can rev it up over the stumble by working the throttle open closed open closed etc...
With all unplugged (afm, tps, ect, hac)
-It will not rev over 2800 rpm. And ign timing will not advance and stays at the 10 deg
***With the intercooler pipe from the turbo disconnected before the intercooler to simulate a blown hose. It
-no cel
-it Idles irratic 700-900
- -9 vacuum, and smokes like crazy,
-- i can rev it up over the stumble by working the throttle open closed open closed etc...
****with the HAC unplugged the hesitation is only a little noticeable at idle/not driving.
once it is over the hesitation Driving at 2200-2400rpm. It runs and drives fine. I can hold the petal steady in say 4th gear and about 3200 rpms and the petal stays still and the speed matches without any cut out. But if it is below 2800 to 2200 rpm while driving the throttle sucks. Will not hold speed and cuts out.
and no i had not been updating it on this forum because of the unhelpful responses from your posts to people.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I see. So it's my fault.
The only thing you're right about is that you indeed don't get it. All that you wrote is proof. Try reading my posts again. That said I'll give you a final piece of advice: stop making everything so complicated.
ccguy
53
az
no, it is not your fault. you just need to step off of your imaginary cloud and stop being a jerk to people and telling them that they are stupid and you are smarter than them by trying to use a riddle to get them to understand what is wrong. but i truly think you dont need to be posting on a forum that is meant to help people with your "i am better than you" ideology.
i dont doubt you understand the operating systems and etc but your overall proven pompous assness has shown that you might never realize you are a dick.
i am trying to understand the systems and everything. and i will start over and try not to make it so complicated but it is that complicated. good luck with your condition
Oct 11, 2005
3,822
26
Thousand Oaks, CA
LOL. Soo, as far as I can tell your diagnosis involves plugging and unplugging sensors. Don't suppose you ever did the Vf measurements asked for in post #22. Have you by any chance measured the A/F either with a wideband or emission analyzer? I am reminded of the joke where the guy is looking for his lost keys under the street light, because that is the only place where there is any light!
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Yeah, his kind is the among the more difficult to help. Reminds me of the idiom "when you earnestly believe you can compensate for a lack of skill by doubling your efforts, there's no end to what you can't do."
At least I know when I'm being a dick...
