Help please
fiddesmkIII
Fiddes
Jul 19, 2005
13
Ontario
I recently have taken apart my entire interior. Front to back. I have painted it all black and am putting it all back together..... but the guage cluster is giving me trouble. MY RPM's wont read and as far as I can see all the wiring is plugged back in correctly. CAN ANYONE TELL ME WHICH WIRES EXACTLY ARE FOR THE RPM's (tach) and also where it gets the rpm reading from in the engine bay???
Thanks in advance
Kris
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
did you take off the needle ? if so, did you put it back on with delicacy ? maybe the needle is on there too tight or bent ?
When I had mine all apart, I had to be extremely careful taking it off an putting the needle back on ...
Will
b005t3d
505
bellevue,nashville, tn
if you took your needles off, youll never get them set back to where they are supposed to be. i took mine off because i didnt know that the lights for the cluster where in the back and ended up having to buy a new cluster because nothing would go back to normal. hope it works out for you bro.
boost
