Hey guys,
Hopefully you can help me out here.
My car was running fine and dandy right up until last Saturday. When I went to go for a drive on Sunday, it wasn't running properly. Weird.
What happens is when I push the accelerator it bogs down massively and sometimes stalls, sometimes the revs jump around and it runs rough, but still doesnt go anywhere fast. If I can actually get it moving at faster than 10kph, when boost comes on it takes off and drives fine the whole time it's on boost. It's only off-bosst that is a problem. Idle is also relatively fine.
What I've done so far:
- Checked and re-checked all hoses and vac lines. No leaks.
- Checked codes - I get a code 51. Now, this code 51 has been there since I did the engine swap. I don't have A/C hooked up, so I've always associated it with that. I read JetJock's article on code 51 and checked the TPS just to be sure, and it checks out fine.
- Cleaned the ISC valve and the check valve (wasn't very dirty to begin with)
- when the car was idling, pinched the ISC hose near the accordian pipe - the car's revs went down and it stalled.
- I can hear the ISC do its clicky thing when you turn the car off
- unplugged the ISC valve from the harness and done a cold start - however, my revs didnt go up to 1500-2000, they stayed around 1000-1200... does this mean it's buggered? It sounds like it's working and it looked fine to me when I pulled it out and cleaned it.
I really need to get my car back on the road, so any help would be great
