hey guys i just got my motor back from the shop that rebuilt it for me. the motor has been gone throught with all new forge piston, new head gasket, the head has been redone, and i just put in pte 580 injectors.the car has most aftermarket things done to it greedy timing belt, 250 walbo,new ngk wires, new plugs, the motor was running fine before with the same set up but then due to other problems i blow the head gasket and had the motor redone. so now i'm putting it and the car will just crank fast and nothing else. the car does have the maftpro on it,. as some of you all know me and my dad have alot of supras at the house and can swap most any part pretty easy.
things we have tested.
1.took cps out of the car lined everything up put it back in and didnt change anything.
2. too the cps out of a running car and lined everything up and didn't change anything.
3. changed coil packs didn't change anything.
4. changed ignitor didn't change anything.
5. unhook the 1st spark plug wire and test to see if it had spark and it does.
6. check all the grounds and fuses
i need help to get this motor running please let me know anything you all can think of. sorry if i missed spelled anything thanks
