Help fuel pump not getting power help me rewire
baldeagle432
20
killeen
ok so i finally determined the pump isnt getting power on my 2jz swap but i havnt quite determined the best way to wire what wire form the 2jz ecu is for the fuel pump so i can wire up this relay
sc4me
4
miami
i believe the green one with the red stripe is for the pump, and if u check the other big one next to it with the ignition turned on for powerthen all you have to do is wire them 2 wires together. i read that in one of these forums to bypass the fuel pump ecu and it worked for me.
