Help front brakes rubbing cant move front wheels
baldeagle432
20
killeen
ok so with the old calipers there were rubbing and would mae the front wheels stic i threw on some new calibers and bleed them on no lucy not its even more stuck i was thinking maybe a abs issue since it isnt working becaise its a 2jz swap so ya someone please please help
SrBigbutt
340
Spring, TX
I had a similar issue and it turned out to be the master cylinder. It would not release the pressure when you took your foot off the brake. Bled it over and over until I replaced it and it worked fine afterwards.
