Heater Relay?
One Jay Z
Supra Dupra
Dec 20, 2006
108
SK Canada
My heat only blows on max, will not blow on auto or 1 2 3 etc.. Would this be the problem of the relays? If so, where are they located and which replacement relays could i use? do they have to be off a JZA70? (my car is a jza70 RHD etc..) Also another question i have is if a usdm powersteering rack would work with my car. i've been told yes it would and i've also been told no. Just thought i'd verify this, im pretty sure it wouldn't myself but u never know.
One Jay Z
Supra Dupra
Dec 20, 2006
108
SK Canada
I dont know if this is the case though. Its somewhat odd too cause the two middle vents (not the vents by window) will blow cold when i have defrost on. When i have it on the -> setting, all the vents will blow heat. But i can never get it to go on auto 1, 2 or 3. just max. as for the power steering, its not a HUGE problem, i could always change to a manual rack. but, if anyone could shed some light on it, it would be appreciated. Thanks.
BTW matt where did you get that intake from?
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
There is is resistor inside the blower motor housing that has a ceramic electric conductive strip on it. They usually crack over time and thus, giving you the ability to only use certin heat ranges, depending on the crack.
My 1jz only works on medium and high. My NA only works on the same, after I replaced it with one with a lesser crack. I need to buy a new one, one day.
Big Wang Bandit
Feb 21, 2006
7,551
Possibly contact Toyota too... They may be able to help since you can import cars legally there!
Matt, Yeah, I just appled constant vac to the to ot the heater valve, so its either cnstant heat, constant cold, or off. Better than none!
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
Toyota still doesn't provide us catalogs for other countries... though we can get our paws on them. ;) ;)
I'll post back in a few minutes as to whether they can be ordered here.
supra90turbo
shaeff is FTMFW!
MA, 01440
It's the blower motor resistor. How do I know? I work at a chevy dealer, and GM has NFI how to make any electronic components, and thus, they leave the blower motor resistor's element exposed inside the blower motor, where there is moisture and they slowly kill all the slow speeds until only high is left.
It is indeed the resistor.
One Jay Z
Supra Dupra
Dec 20, 2006
108
SK Canada
Jeff Lange said:
87138-24030 $62.63 My retail.
(Fits up to 05/92, after that it's a different number, not sure if they interchange)
You have access to oem jza70 parts i take it?? or is this off a usdm model and is interchangeable
