Heater Control
bhg4life
Frozen
Apr 13, 2007
34
Edmonton
The heater control for my 88T is not operating properly this morning.
Symptoms:
- Fan works when you manually push the buttons manully.
- Auto mode will not work to heat (set to max - 32C), but works perfectly fine with you you set it to 18C to cool the car.
- When you manually run the fan with the heat set to max it feels like a small amount of heat is coming out, but it is hard to tell for sure.
TIA
