Headgasket choices and recommendations
boostedmklll
Omaha, Nebraska
I have a 90 supra with 115000 miles. Stock block and head. 57trim ct26 greddy front mount with 3" hard piping. 3"downpipe and 4" exhaust. Lexus afm rc 560cc injectors. I recently started seeing smoke out the exhaust. Did a compression test and cylinder 6 is barely 100psi. Going to get head decked and do the head gasket with arp studs. Just wanted some recommendations on what head gasket to run. The car is an scca autocross car and gets driven hard. Currently running 14psi. Thanks for your help everyone.
Then as long as the block is clean and straight mhg should seal.
Doesn't matter which one you use they all work.
The hks stopper is the best. Bit pricey tho. All the others are pretty close to the same.
