Cya said:
Well I know abotu air flow on the V8 sights, BUT im wondering about the supra NOT the V8. SINCE the V8 HAS BIGGER EXAUHST PORTS THAN INLETS, it will on provide more ariflow. If you haven't notice the 7m has a revision damn built in (should be a clue in to assholes that i've done some research), i.e. intake is bigger than the outlet. What I want is proof, not hearsay (there's a difference) of what will happen or around about what will happen on the 7m head not a Chevy small block.
souprat said:
Forcedtorque, you rock:bigthumb:
and one more thing. if your going to port the thing you should also look into a 3 angle valve job. i suggest it because it will improve your low lift flow and i dont think your going to be running cams with radicaly high lift. it will complement a port nicley with stock cams.
bo3232000 said:
If I am correct i beleive that the dams help with creating a suction out of the head and with out them the exhaust has a harder time exiting,thus creating more backpressure and more lag on spoolup....There job was to create a more balanced exodus of the gases before the turbo to even out the pulses and create more draw on the non turboes...Hopefully this will clarify the answers you have recieved so far.......
http://www.supraforums.com/forum/sho...d.php?t=270783
http://www.supramania.com/forums/showthread.php?t=3793&highlight=port+polish
http://www.supramania.com/forums/showthread.php?t=7685&highlight=port+polish
http://www.supramania.com/forums/showthread.php?t=5499&highlight=port+polish
What is Flow Port-Matching?
Flow Port-Matching is the process in which each port is flowed and
matched to the highest flowing port. During this process, each port is
flowed and the head removed from the flow bench and reworked with the
grinder, then flow tested again. The head is taken on and off the flow
bench and ported more, numerous times, until the desired CFM is
reached for that port. Then the next port undergoes the same process.
http://yarchive.net/car/porting.html
If u searched here and google for 2 hours and couldnt come up with any thing, then u gotta problem.
took me 10 minutes, and im sure theres lots of info i just left u by simply SEARCHING. so ur smart ass comments just made u look like u dont know jack SH&* when it comes down to searching.
have a good day bud.
