Harness Plugs
Intrnlstorm
One Jizzle
Aug 27, 2006
123
Schenectady, NY
Decided to start putting the supra back together and can't remember what these plugs were for. If anyone knows, or can point me to information that would be greatly appreciated.
They are on the passenger's side right after the headlight grommet.
Joel
JonoTurbo
Going for broke
CT
The dark gray plug in the 1st pic looks like the headlight motor connector, and the other connector looks like the one for the bulb.
The 2nd pic looks like a foglight connector and a washer fluid reservoir connector.
The connector in the 3rd pic I don't think connects to anything. I remember having a plug like that not connected from the factory.
Intrnlstorm
One Jizzle
Aug 27, 2006
123
Schenectady, NY
Headlight motor hooked up and the headlight too
Foglight not hooked up yet I will check this. The washer fluid is all hooked up though.
I think I read somewhere that it was for A/C for a automatic car.
Thanks,
Joel
Satan
Tampa
They look like the connectors for the 2 relays (I think) which are over near where the air filter would be at. They are usually mounted on the side of the strut tower. Anyone else have a pic or know what I'm talkin' 'bout?
JonoTurbo
Going for broke
CT
In the 2nd pic those connectors could also be for the AC pressure switches.(Which I think is what Satan is talking about) I've got no clue on the ones in the 1st pic now, the pale yellow one might be another one of those connectors that doesn't get used.
