gte intake on a ge?
modmonster2008
mod crazy yo!
Sep 9, 2008
1,051
Seattle, WA
As the title states, would a 7m-gte intake manifold fit onto a regular 7mge? because i am gettin irritated about having to remove the TB to replace the plugs instead of the middle piece tht says "3000" on it? cuhz if it does ill just plug all the un-necessary hose adapters and put the ones im supposed to have on there, i like the gte intake better, someone let me know thanks!
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
It's not just that you lose power, but the power and torque curves get a even weaker in some areas than the overall loss. If that makes any sense.
Look up the specs for a stock Cressida... granted I think the ECU's a little different too.
gelboy1015
Vroom Vroom!
Jan 1, 2007
234
Houston, TX
yea i asked the same question, except i wanted to use a cressida intake..
read up more about the ACIS.. theres a sticky up top somewhere
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i've just gotten to where i undo the intake pipe into the TB and take the four bolts loose, then lean the whole throttle body up and towards the brake master cyl while i change plugs 3 and 4.
CRE
Oct 24, 2005
3,485
Denver, CO
Can't imagine why anyone would have to go further than that.
webbs7mgte
298
wisconsin
if i am correct no it wont. well sometimes im not correct. but if your overheating common things i look at is
-coolant level
-white smoke out hte exhaust
-thermostat
-faulty hose
