gt35r comparison
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
Hey everyone, I had a specific question about a gt35r. I doubt many mkIII owners run them, but I’m interested in buying one with a t4 exhaust flange (yes 935motorsports.com makes them with t4 exhaust housings). I saw an evo8 with a Garrett gt35r pull at torque freaks, and it put down 498 awhp. I realize it had a t3 exhaust housing, and not a t4 like I have. But for arguments sake, lets pretend that his t3 housing and the t4 housing (.82) that I would be putting on are the exact same. He was running a safc, I have a map-ecu, and lets pretend that both our exhaust and intake combinations were equally efficient. He was using a tubular manifold, and that is what I have. My question is, with everything equal, will my larger displacement 7mgte put out more horsepower than his cammed 4g63. I realize that the evo8 4g63 is a lot more technologically advanced than the 7mgte, but could my motor compete do to the larger displacement?
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Flow approx 63lbs of air, max boost of 34psi. If pushed hard enough, I would think you could make the upper 400's, low 500's with it.
This is a 60-1 compressor map. The 60-1 wheel with a p trim turbine has been known to make the 500hp mark.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
i have to add, for the people wanting a 60-1, this is the upgrade you want, as it is actually quite reliable. Actually compared to a normal 60-1 with just an upgraded compressor wheel, the p trim is the cat's meow.
MDCmotorsports
Indy 500
/off topic, but the 60-1 wheel has a problem with surging in a ct26 housing. Thus the failures.
7m's love p trim turbines.
7m's also love the F1 style turbines used on the gt35r. Its a modified stg 5.
