GRR, still not able to boost.
89turboguy
196
Denver, Colorado
Well my statement has changed from my previous thread. My car starts to build boost hard then gets to like .5 bar and starts to cut out, not harshly like fuel cut, but more like i had a carb and it was flooding. From then on my car wont build anymore boost nor go any faster. I took my car to a shop and had them look. they said it was the intake so i got one made and put it on. My car still does the same thing. i am really getting frustrated with this, and i am running out of ideas. someone help me!:1zhelp:
peteyturbo
59
Philadelphia
I would check the plugs and wires and do a boost leak test..Are you using stock fuel management??Need more details..
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i opt for boost leak... vac line off somewhere... something! listen for a hiss might be somethin tiny ;p (like when my t connector fell off)
89turboguy
196
Denver, Colorado
No codes, No leaks(that i can find, i need intercooler hard pipes to be sure.) No shaftplay, Timing perfect. And yes i am using stock fuel managment. But before you say that is my problem, i do not think it is, Because it ran perfect for around a month with the same setup.
