Greddy turbo timer help
pgiller
Boost addict
Sep 16, 2008
260
Licking MO
I have a greddy turbo timer and I cant get it to count down. I have all the wires hooked up right but when i shut off the car the timer shuts off to. What is causing this?
JustinGotA1j
532
Chilliwack
I had the same thing with my HKS turbo timer. There are 2 different ignition wire. If your problem is the same as mine which it sounds like then you hooked your turbo timer to the wrong ignition wire. try the other one and see if that helps. Unless of course you used a harness and did not hard wire your turbo timer, in that case I have no idea lol.
pgiller
Boost addict
Sep 16, 2008
260
Licking MO
I didnt hardwire it, it had a harness with it. And I found the manuel on the greddy site and followed all the directions but still nothing.
Deathseeker31
Getaway Driver
SOCAL
did you program it? i know on my timer it has a lot of options and if you don't have it in the correct mode it will do what you describe. can you per say add time to it and will it count down then?
If that's the case you have it on the wrong setting.
To change it from settings you have to hold down the power button and press i believe is the second button to the right. I don't know have my manual in front of me as i cannot remember the lingo but try that and see what happens.
