Gotta ask this once more (white smoke)
Kiraush
62
Medford, Oregon, United States
Alright, I already asked this once before, but I've gotten so many different answers that I need to ask again and throw some "facts" I've gotten.
I have white smoke at start up, only in the mornings and after the car has been sitting for a little while (I would say about an hour)
The biggest answer I've got is valve stem seals, but don't those have blue smoke at start?
Second biggest is blown head gasket, but wouldn't the smoke persist after start up? And wouldn't my oil be Milky? (it isn't) and wouldn't I be going through coolant like mad? (I'm not)
My mechanic grandpa of thirty six years says blown head gasket, his mechanic son of like twenty years says valve stems
My brain hurts
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
LOL.
It's normal(depending on environmental conditions) to have a little white smoke(that evaporates) on startup when cold.
If you're not losing ANY coolant, you're probably fine. If you ARE losing coolant, do a block test and find out for SURE.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
supraguy@aol;1952003 said:
LOL.
PS- MFR looks like a pretty good-sized Class D airport, but being as I'm usually in a BE40, I rarely get out to the northwest areas, and when I do, its usually
SEA,CYVR, etc.
jake8790
Life's too short for N/A
Dec 18, 2011
395
Oregon
Correct.
If the steam starts immediately, it's probably a BHG as the coolant is burning in the combustion chamber. If it takes 30 seconds or so to start, it's probably just condensation in the exhaust.
