gota quick question
brs86supra
395
suffolk,va.
ok i have been having a problem with my car not driving and idling right, so i checked my codes and it gave me a code for my afm so i went and got a new one and reset the ecu and it idled and drove right for a second and then went back to not idling or running right. and i am still getting codes 24, 31, and 51. what could my problem be. any help will be greatly appreciated, i have been trying to figure out this problem for quite some time now. thanks in advance
8,900
You get codes because the ECU is not seeing the correct signal it expects, not becuase a component has failed.
Not to say a failed component won't store a hard fault.
I could guess that with two air flow meter codes, you do not have a good power source to the meter.
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Yeah what Nick M said!.. That 51 is probably an adjustment issue. Search the forum for adjusting the TPS. Be prepared there are a lot of post but plenty of instructions. TSRM might be faster!
brs86supra
395
suffolk,va.
could my problem be that my wiring harness is very brittle and whenver i mess with a wire the wire breaks from being so corroaded and green on the inside of the wires. the wires going to my afm are almost broke so could this be my problem
slidebabyslide
Starting FRESH !!!!
Dec 17, 2006
662
salinas,california
:naughty: NO thats not your problem:nono:
lol., yeah man my car would always have a code like ones a month lol. so i finally washed my motor because it was dirty and my car would not run lol. so i learned that , never wash you motor is your car was wires all out there. lol
and yeah old harness just don't do it any more.
just try to find a good harness or rewire it.
8,900
Most likely.
When you come across the terminal repair kit, use good crimpers.
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
i had the same prob with code 24 and i even bought a new afm as well.. turns out it was just the wire lol oh well.
8,900
Go to the parts counter at Toyota and ask him. He might tell you Toyota, and that it isn't available to you. Ask Jeff Lange, I think he said he is sitting behind the counter.
brs86supra
395
suffolk,va.
ok i just repaired the wires on the afm and put new female terminals on them and now the car is still doing the same thing it was doing before. i cant figure out what the problem is and soemtimes it wont even start. what could my problem be. any help will be greatly appreciated. i wish there was someone near by who could come and help me figure out what hte problem is.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
trace the harness back from the afm plug, and look for any damge,
you may have such corrided wire it finaly gave it's ghost, but i doubt that, you just haven't found the source of your problem.
buy a dvm and start checking continuity and resistence.. perfeibly from ecu pin (while it's on) and to the afm plug.
you could also test for voltage and see if the afm is sending the right signal to begin with. and to check to see if thw ecu is sending a 5v signal to the afm.
brs86supra
395
suffolk,va.
ok i finally got my car to run again. all i needed was a new wiring harness throttlebody tps and coolant temp sensor. got all of these parts in last night within 3 hours. it took me 3 hours to take out the old harness remove all the necessary intake pipes, throttle body, upper intake manifold, old wiring harness, temp sensor, and i even romoved the fuel rail and changed out my fuel injectors, and put all the stuff back in its original place. i started at 8:00pm and finished at 11:00pm. and the thing that makes me proud is i took out and replaced all these parts all by myself. i appreciate everyones help, i could not of figured out the problems if it wasnt for my fellow supra owners.
but the car seems like it could run better, but i'll worry about that later, have to get a couple of kinks out of it, but im just glad its running.
