Getting front bumper off? help?
7mgte_supra
The Hmong Guy
Nov 4, 2006
51
chico, Ca
Can someone help me get my pre 89 supra front bumper off? i'm having some difficulty getting it off. Can someone help me? Some pics would be great.
bgrieger
Toronto
remove under cover, corner under covers, remove wheel arch liners (if you want...makes access easier, otherwise unbolt them from bumper and reach around), remove side marker and trim, corner lights and fog lights, remove grille, unbolt the stays on the inside of the bumper on either side and walk the front end looking for bolts...basically, anywhere you can see the urethane bumper gets close to metal you can expect to find a bolt. Keep pulling bolts until it practically falls off.
Is there a specific area you are having trouble with?
-Maniac-
They call me Nate.
Aug 25, 2005
Birmingham, AL
Exactly as above. I have some pics at home. I'll try to post them tonight.
You'll have to remove the fog lights. Remove the trim and side marker lamps.
Remove the inner fender liners... the screws are accessed inside the fender wheel well.
Remove the outer bumper supports (They're behind the fender liners).
Last, remove the Main Bumper Bolts. They are 2 big bolts that go through the frame. Access the nuts from underneath, then pull the bolts out the top by sticking your hand through the opening where the grill was.
Hope this helps get you started. I'll see about pics this evening...
