Geougenator's 89t build! What's 56k?
darkside88T
22
Richmond, Virginia
Well, its pretty much over now, but here is how it went.
This is my 89 turbo targa that I purchased a little while back (not running) from a guy in Elizabeth City, NC. I have been doing all sorts of stuff to it since then, with plenty of help from my friend Squid699 here in Richmond. This is the 3rd non-parts Supra I've owned since 98. My first was a beautiful 86.5 pearl white 5spd, and the second a red 88 turbo targa 5spd. I have been involved in several Supra engine builds and projects over the years, both personal and assisting others, with many disappointments and successes. This is the most thorough build I have done thus far, but expect that there will be more elaborate expeditions to come.
I decided to swap the stock maroon interior out of the black car with the gray interior out of my old 88. I then sold my 88 as a red on maroon, which sounds disgusting, but to my surprise it was actually decent looking.
That's Chris working while I take a picture break.
I swapped everything that I had upgraded on the 88 before I sold it. Here is the car after swapping the interior, suspension(Eibachs, KYBs), drilled/slotted rotors, ADR wheels, and fuel pump(stock for walbro).
I had spent the last few months slowly gathering parts for the engine rebuild and putting it all together. The machine work was stunning, especially the block. I had it bored .020 over, resurfaced, and cleaned. I decided to go with nippon stock cast pistons so I can run tighter clearances and I do not plan to go too crazy with this motor. I think 400rwhp is a reasonable goal, and the stock internals should do fine with a good tune.
Out with the old engine and auto tranny.
Rebuild and 5spd going in. My bro's 85 Celica GTS convertible can be seen next to mine.
darkside88T
22
Richmond, Virginia
Thanks for all the great feedback!
SupaMan: The interior wasn't too bad, the hardest parts were the trunk panels and the targa lining + side rails. The rest is pretty straight forward. The dash is pretty easy if you know where all the bolts are.
I have some video of the car running on an open downpipe, I just need to upload it somewhere and I will post a link. All thats keeping me from driving it is a clutch fork, and that is on the way from Champion Toyota!!! More pics to come after I clean it up some.
Squid699
Manic Mechanic
Chesapeake, VA
I can't wait to get this thing on the road! Hopefully I can get that other lower ball joint installed without your car hating me any more....
funny how you didn't mention our little coolant leak problem, lol
EDIT: You didn't menition the FUN with the pass door and driver door hinges, either ::rolls eyes::
Your interior is awesome. I love the grey alot more than the maroon. Sorry, maroon guys............:biglaugh:
Waiting patiently for the video.
darkside88T
22
Richmond, Virginia
I did the other ball joint yesterday, along with the tie rod, exhaust, and fan. I also wired in the stock stereo harness since the previous ownder had cut it :icon_evil , but apparantly I need a different adapter harness for the stereo... looks like they are different from 88/89. Oh, and thanks a lot for bringing up the freeze plug and door hinges... so much for blocking out those memories lol. Basically, the lessons to be learned here are 1: don't forget to put the little freeze plug in behind the timing case and 2: when changing door hinges, do yourself a favor and take the fender off first thing.
Here is a short video, I will hopefully have one that shows more up soon:
http://s192.photobucket.com/albums/z24/geougebv/?action=view&current=ade1fc9f.flv
darkside88T
22
Richmond, Virginia
Thanks! We are definately on the same page :icon_bigg
How'd the other Ball joint go?
It went OK... I just cut off the side of the bolt with the dremel, but if I had to do it again I would have tried taking the bottom strut bolt off first. The tie rod was loose like the other side.
Car sounds awesome Geouge! I can't wait to see this thing in action
Thanks! I want to see YOUR car in action, though I hope it won't make mine feel like my Hyundai afterwards. Thanks again for the water pump too.
Here is a longer video, much more has been buttoned up since this, so more pics and video to come!
http://video.google.com/videoplay?d...=15&start=0&num=10&so=0&type=search&plindex=0
