Gauge Question!!!
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
Alright i was looking on jcwhiteny today and they have autometer gauges really cheap... why is that i see like a boost and air fuel one each for like 50 bucks... anyone got one from here?
they say they are a 2" face so that would fit into my 52mm pod right?
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
auto meter are great products its all i use my chevy pick up with 8 inch lift and 38 inch tires had autometer tach and gauges never had a problem and i beat the fuck out of that truck, (mud runin) my caprice has them 2 never had a problem, my supra has a apexi boost gauge and i like it alot to my own surprise but prolly will switch to auto meter
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
I'll trade you my autometer boost gauge for your apexi...... :biglaugh:
Supraholic
Houston, TX
i never bought anything from jcwhiteny, but, the 2" gauge should fit the 52mm pod. Mine did. The gauge is nice and tight in there..
jester1341
topless and blown
Western Maryland
i'm not down with autometer....never really liked them. never bought any, a friend has two in his V8 86 RX-7[water temp and oil press.] work alright i guess
but i guess for me it's that too cheap to be good feeling, and they look(to me) like there about to break
john
Jonnymkiii
High Altitude
Boulder, Co
I've talked to some people that have quality tested several different brands, and the results were that Autometer gauges are no less accurate than the more expensive gauges such as Apexi, Blitz, HKS, Greddy, Defi, to name a few.
You also need to decide if you want mechanical or electronic.
Mechanical gauges require you to provide a source of what is being metered to the gauge - ie for boost, you will need to run vacuum line to the gauge.
Electronic gauges usually have a metering device that can be mounted in the engine bay, which in turn connects to the gauge with a few wires. This is good for metering things like oil or fuel - you don't want to lines for those in your cockpit :) Also, electronic gauges allow you to set warnings, hold peak, and memory. These will most likely require a separate controller unit.
Do some investigation and pick the one that best fits your budget and needs. The more expensive gauges look nicer at times, but also, sometimes that is what you are paying for - vanity. If you just want functionality, Autometer should do the trick.
tte
Breaking In - in progress
Northern California
i hate the water temp and oil pressure mechanical meters becauseb i do not like running all the hoses into my interior.
Cheers,
Roy
JBatt87T
102
Athens, GA
bigal0043 said:
alright thanks.. yea i have a mechanical boost gauge already and it sucks ass.. so i will just get a mechanical boost one...
So you have a mechanical boost gauge that you don't like now....but your going to get another mechanical one??????
Please elaborate.
JBatt87T
102
Athens, GA
I would go with electronic just for the fact that you don't have to run all the vacuum hoses and shit into the cabin but that's just me. I just purchased a set of Greddy boost and EGT electronic gauges w/ the peak hold & warning features.
