gauge hookups, searched
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
ive looked for information on here about hooking up an A/F gauge and a water temp gauge. so far, i think that the water temp/coolant temp sensor is in the housing that the upper rad. hose leads to. which of these will i need to put the new sensor in, and can i keep both the stock temp and the new temp gauges working?
as for the A/F gauge, im thinking i can just tap into the oxygen sensor wire. anything special for this?
since im putting the two gauges where the cig. lighter and ashtray are, can i use the cig. wires to power these gagues? constant power and then the lighting controls, of course. anything wrong with it?
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
yes you are right about the 02 sensor just tap into the lead wire.( you'll have to try until it works) just tap into it. as far as the cig wires, yes thats how i had mine done before i got my pod.
