hey i have the spacer for the Pipe Fuel Delivery Inlet but i dont hvae the two gaskets and i have gas leaking from it does anyone know where i can find these gaskets cheaper than a dealer? or can i use some metal gasket material ?
The copper gaskets for each side of the banjo bolt? They're very cheap, even at my local dealer. A few of the auto parts stores around me stock them in many sizes, you just need to take in the banjo bolt and they'll find the right one.
Man if your'e having a hard time with the gas can your'e in trouble.
The gaskets aren't bad at the stealership. Go and invest a couple hundred into it now so it's not a couple grand later.
Same answer dude...., Stealership, easiest and probably the quickest way. That won't cost much and they may just give it to you if you play up about your going to be in there in a few days to arder a few hundred bucks worth of parts. Play the game...., steal the base.
