viperkillertt;1326064 said:
I also would like to know the maximum size of injectors for the 2j/1jz fuel rail. Can we use larger then 550cc? I was told that 550cc was the max before needing to change to a larger fuel rail.
You can use any size injector you want, but the rail is going to limit how much you'll be able to use them efficiently due to the stock stingle in/out. You can modify the rail for dual in single out, and although I've never tried it you may be able to use a T fitting and not modify the rail at all.
The problem is the last injector (#1 on stock in/out) doesn't get enough fuel past 550whp usually. It's possible to go higher with dual pumps, but I wouldn't take it too far. Having another feed to the other side of the rail would fix this in the perfect world I live in that also has no mosquitoes.
I don't really like my top feed rail. Such a pain in the ASS to keep the injector guides in place while you're trying to put the injectors in and keeping the seals from falling off... After swapping the rail/injectors out four different times, it doesn't get easier.
