Pull the pump and see for yourself. Is what I would say if I didn't have mine out already. I'll check back in later tonight with that 411 and I have a 91 na, just so you know.
new question... where IS the fuel pump. i guess i was messing with the fsu not the fuel pump. i feel like a dumbass now. haha is it in the tank even? thanks Justin
You have to drop the tank. In the back of your hatch lift up the well cover and there is a cap you undo those wires and the plate has to be removed after dropping the tank to get the fuel pump out.
Be carefull not to bend the metal tubing as if you do you have to buy the entire fuel pump assembly and it alone is 66 bucks wich wasn't as much as I thought it would be, but still.
