Ok! Here's my problem, a bit ago I got a '90 shell to drop in the engine off of my 87 since im planning on going 1J on my 87, well here is when my problems beggin I got a '89 harness thinking it would be an easy plug and play just to get the car started, Well I was wrong. the main plug on the '90that runs to the body is different than the one on the harness, this ist the body connector on the '90 which has 13 wired pins,
This is the '89 Harness that has 18 wired pins
which matches the '87 yellow plug harness. every other plug fit in just fine. Well I repinned all the wires on the main plug with the body colorcoded and matching but I have 5 wireds from the harness that dont have anywhere to be pined because of the body harness having less wires. so the car turns but my fuel pump doesnt turn on! cant hear it at all. Ill post pictures later today of the wires that havent bin plugged.
