fuel cut
s7mgte
136
ny
i have an upgraded 60-1 ct26 and downppipe and safc and whatnot and was wondering when id hit fuel cut and when i did hit it.. how to eliminate it.
mkIIIman089
Ohio
You need quite a lot more flow before you even need to worry about it.
Spend your money on fixing your car.
s7mgte
136
ny
before i need to worry about what.. and i did fix things.. i put a new metal head gasket and arp studs and whatnot in.
You should drive it and hope that you don't hit it. You may not hit it and if you do then you've answered one of your questions. Try to see how much boost your at when you hit it and then we'll go from there.
JJ........sarcasm becomes you.............:biglaugh:
jtran8
199
wichita kansas
You need to list all other mod youv'e done beside 60-1 , safc and down pipe. Anyway with stock afm + 440cc , fuel cut at 8-9 psi of boost (300rwh) with that 60-1 ; however with lexus afm +550cc + good tune people run 18+psi ( 430rwh or more) without fuel cut with that 60-1 . Make sure to check for boost leak before you turn up the boost , if you have big boost leak(run rich) you'll have fuel cut at lower boost level .
