Fuel cut and wideband o2 location
Suprasath
27
Toronto
As the title says I need to find out how to get rid off the fuel cut after 14psi. I have the maft pro hooked up and the afm is removed permanatly.
Also where to put the wideband o2 sensor on the exhaust. If any one has an idea just leave a msg
Thank you
alloyguitar
it's legal, i swear...
knoxville, tennessee
The wideband shouldn't be mounted on the bottom of a bend where it could collect moisture, and shouldn't be less than 2.5" from the compressor wheel (I believe. May want to check me on that).
Mine personally is mounted under the passenger floor with the wiring run through the floor and into the glove box (with all the proper grommets, of course).
