Front Clip, Engine Where to Buy From 2jz 1jz?
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Well, I will be starting my search for a front clip with a 2JZ, or a 1JZ. I was curious as to where I could find a good deal. I am not really even sure the places to look, so any address, phone number, or emails you can give me would be great.
Thanks for all the helps guys.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
id only go through site people especially for a 1jz.. DM .. kaizen etc
i bought two 2jz's from japanmotorimport and was satisfied but it might be a better deal to get the front clip from an aristo since its less likely there will be damage on the engine itself (good if you want to use the stock twins)
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
arnt they no called front clips no more? correct if im wrong. but i was told they no longer sell front clips, try our venders here liek DM they might have what you looking for =D
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
Aaron with Driftmotion has stated he gets calls for 1jz clips daily and any that he might be getting I'm sure would be spoken for well in advance. You would be better off getting an Aristo 2jz front clip, or you can start piecing together 1jz parts for a swap. Either way it is going to be $$$$$. I'm thinking a 2jz would be sexy as hell under the hood of my, um I mean, any MKIII.
Here are some links
http://www.supramania.com/forums/showthread.php?t=80674
http://www.supramania.com/forums/showthread.php?t=80675&highlight=front+clip
http://www.supramania.com/forums/forumdisplay.php?f=138
http://www.driftmotion.com/
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
Here are some links
Well I think a 2jz or 1jz would look great under a teal supra hood.
thanks for the info man.
tlo86
Jul 24, 2005
3,914
Colorado
only real reason to go aristo front clip is if you have a gs300 or really want to know the actual mileage. i had to change so much on the engine anyway i opted for the engine by itself. (need diff oil pans, mounts, i went straight to single etc)
