Force to open Loop
Slash200
21
Traunreut
Hello,
is there a way to force the ECU to run allways in open loop?
It would be much easier to tune with the translator pro.
regards
Bastian
90mkiiisupra400hp
169
Gardiner, Maine
I am not sure but I think you can unplug the stock o2 sensor to force to open loop. Hopefully someone will confirm this is the way to do it.
I was thinking about putting a switch inline of the o2 sensor so I could switch it from closed to open when ever I wanted but I just never got around to doing it.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,244
46
Atlanta
I believe that disconnecting the O2 signal will cause the engine to go to an over-rich mode and store a code,
but I guess that could then allow you to tune it back to a leaner setting...?
