For fun I took part the black afm box with pic's as well
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Well I was bored today and did some reading as I do alot
first off read this so you have an idea on how it works
http://www.aa-academy.com/asp/info.asp?id=60
again I must say this, I have been getting asked about running an afm in blow though mode there no reason to do it it will just fail faster and not read properly aka don't do it if you want you bov to sound like a boat or train buy some thing els
afm vent so this mean if you put 25 pounds of boost into the pipe box is now has 25 pounds of boost
afm mirror for light emmting diode and the photo transmitter to pick up vibrations the mirror is set up like a leaf spring, kinda like what you see in leaf spring based suspensions and very delicate
all note under side mirror is 2 holes of air channelling these are what clog up form oil based filters and coat the mirror as well
the thing that stick out act's like shackle for the leaf based spring
shitty pic of the diode and photo t
the brain of it all submerst into gell
on side note the mirro has really neat textrue under the scope
so really back then Toyota's karma is far better then hot wire ever could be but could not be used properly in blow though since the persure and oil gather would just mess the sensore up pretty fast and when most meter break the spring just snaps
NashMan
Aug 5, 2005
4,940
17
Victoria BC
yup I would never do it there's no point at all........
you can only mess with the ecu so much befor you are in unchart ecu map zones that know one even knows? only toyota and mabey Mines in japan
or over all dirty reading from the kama
so it's bloody guessing game
and most cals are calculated distance form throttle body and restaince for the air getting there ect
te72
Classifieds Moderator
6,619
9
WHYoming
Leave the blow-through to the carb guys. :p
This has always been in my eyes the weak link of running boost on engines with a MAF setup like the stock 7m... Works great for NA engines though. :)
