Fog Lights Question
killarb634
Jersey's here
OK was changing my fog lights today beacuse they were old and nasty looking. Plus they didn't work. So i put in the new fog lights and they don't turn on. Took the bulb and hooked it straight to the battery to see if it worked and it did. Used a multi meter and checked if the fog light wire had power to it. Well it did but the fog lights still will not work. Any ideas about how to fix this?
Thanks alot
Brian
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
stupid question, but did you make sure to check both plugs and clean up all connections?
8,899
Power for the lights is 1/3 of what you need. Do what clip said and clean the socket. You must also have ground, or the light will not illuminate.
killarb634
Jersey's here
both plugs? There is only one plug that comes off the light and one plug that it plugs into. I checked the plug from the body harness and checked that one with the multimeter.
Clip
Oct 16, 2005
2,738
9
Virginia
reach back, if i remember right the ground plug is about 4 or 5 inches behind the first plug.
Clip
Oct 16, 2005
2,738
9
Virginia
the light itself plugs into the harness, and then i think the harness also has a plug or a wire that connects to the housing, like you said.
jdub
Feb 10, 2006
10,730
Valley of the Sun
I'm using aftermarket lights...I ran the ground wire to the chassis connected with a self tapping screw.
