Flywheel question!
Supra-Kid315
Cambridge
hey im doing a swap on my 1989 n/a supra to the 7mgte and i was wondering if i could use a n/a flywheel and clutch on the new turbo engine jus to get it out and moving around the streets.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
Yes, but only if you're using the NA tranny- A.K.A. W58.
PS- If you're using an old OEM clutch, it will slip at anything above ~220RWHP.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Yes, but just to be clear, if you are using the NA tranny then you MUST use the NA flywheel and NA clutch.
And my OEM NA clutch didnt last the moment I pulled out of the parking lot, it was slipping in 5th gear bad.
