Floor epoxy (garage use)?
te72
Classifieds Moderator
6,624
9
WHYoming
MDCmotorsports;1699391 said:
I've heard good things about this...
http://ucoatit.com/pgs/main.htm
I tried the stuff from Menards made by Rustoleum products.
Basically I called Rustoleum and told them to come get their shit off my garage flood because it was exactly that - SHIT.
Needless to say they told me to go pound sand.
If you really want a good epoxy floor, call in a contractor that specializes in such floor coating.
You know, I've never understood where that came from. Who pounds sand???
Anyhow, I'll look into our area and see if there even *is* a contractor for this sort of thing around here. If so, I might be able to get some of their materials to work with... maybe.
suprahero;1699395 said:
I did the floor at Bevill State Community College in the mechanics department with a Tile Clad Epoxy from Sherwin Williams. It's a two part A and B epoxy. I believe it cost me 85.00 for a gallon of each which makes two gallons and will probably cover about 400-500 sq. ft. It's lasted for two years already and that's with them having class in it four days a week with lots of foot traffic and lots of cars being pulled in and out every day.
It rolls on with a 9" roller, but make sure you wear a mask because the smell is horriffic while installing it. Good luck.
Thanks for the experience, I believe we have a SW shop around here, now that you mention it. Could it really smell any worse than 75w90? I'd probably wear a respirator working with anything that wasn't water based anyway, but I'm more or less immune to bad smells anymore.
jstricker
68
Kansas
te72;1699138 said:
Also, talked with mom last night, she knows her stuff about paint (lot of experience and love of the job there haha), and she recommended the Rustoleum over the Behr that's readily available.
I can't comment on the Behr but I have used the Rustoleum and I can't recommend it at all. Poor wear life and chips easily.
John Stricker
Russell, KS
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
IBoughtASupra;1699830 said:
I would listen to SupraHero, he is a carpenter.
Lol that makes no sense carpenters don't necisarily know any thing about concrete coatings being that they work with wood :D but I will x2 his statement I actually was thinking about sherwin williams when I said that paint stores carry their own lines that I would use:) and as far as resperators go use one!!! it doesn't stink like wow that smells bad it stinks like wow my head hurts:) suprahero did you get any roller lines???
Sent from my DROIDX using Tapatalk
te72
6,624
9
WHYoming
John Stricker
Russell, KS
Thank you sir. So, it seems that Rustoleum and Behr are out due to all your bad experiences. Anyone have a bad experience with the SW stuff, in case I can't get anything commercial grade?
Thanks. I made a suggestion. It's up to him to make up his own mind.
jdmfreak;1699892 said:
Lol that makes no sense carpenters don't necisarily know any thing about concrete coatings being that they work with wood :D but I will x2 his statement I actually was thinking about sherwin williams when I said that paint stores carry their own lines that I would use:) and as far as resperators go use one!!! it doesn't stink like wow that smells bad it stinks like wow my head hurts:) suprahero did you get any roller lines???Sent from my DROIDX using Tapatalk
No lines at all. It goes on really thick and it doesn't chip. It's an industrial strength product made for industrial floors. The floors at the college have hundreds of kids on them a week and it hasn't chipped yet.
As for the smell......it's not that it stinks. It will give you a splitting migraine infested eye popping head ache.
Mr. Freak, I'm not just a carpenter. I'm in the construction business. I do my own wiring, plumbing, painting, vinyl, and painting. I know a lot about a lot. I do happen to swing a hammer pretty good too though, so I am a carpenter at times. I'm a jack of all trades and master of none.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Cool sounds like good stuff:) and I assumed you did more than carpentry( like when you installed the floor you were talking about) I just thought it was a funny statement sorry if my comment didn't come across that way
te72
6,624
9
WHYoming
So the Sherwin Williams Tile Clad Epoxy then, is the option of choice it sounds like... Thanks man, I will probably be going with that then. :)
jstricker
68
Kansas
Just to be clear I'm making NO comments about Behr, I've never used it or know anyone that has so I can't comment on it. Thr Rustoleum, on the other hand, I have used myself and I'm not impressed.
John Stricker
Russell, KS
te72
6,624
9
WHYoming
No worries John, I've heard enough about the Behr to sway me away from it. They make good paint though. :)
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
I will soon be pulling up a rustolium floor that stuff is crap thermal shock from the tires peeled the shit right off the floor also for some reason its peeling in other places too I know the guy that put it down and he did all he prep exactly to spec everything was done right as far as prep and installation and it started coming up within 4 or 5 months
te72
6,624
9
WHYoming
I dunno if it was mentioned in here, but have discussed this with my mom before (the peeing from hot tires). Her solution? Floor mats that you'd usually use *inside* the car. Put one on each corner, no more peeling from hot tires on cold treated floor problem. :)
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Yeah but u shouldn't have to park on mats if your paying that much money for a floor coating might as well put a piece of cardboard down for oil drips imo :/
te72
6,624
9
WHYoming
I agree, but is there a substance of this nature for this use that can withstand that kind of temperature shock?
