Filling gearbox oil without driveshaft on?
scotty
476
Norway
scottnicholas.net
Hey. Don't have a driveshaft yet for my R154..
Just wondering if it is ok to fill put gearbox oil in without the driveshaft? Will anything come out the ds end?
Scott
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
Why did you post this thread twice?
And yes, oil will come out the driveshaft end unless you block it up.
And if you don´t have a driveshaft, why do you want to put oil in the tranny?
SupraSean
SPRASEAN MTHRFKR
Mar 3, 2009
487
Pittsburgh, PA
x2
scotty
476
Norway
scottnicholas.net
-First I started another thread in the lubrication category, and it said it needed approval by mod before it would be posted. Then I just posted a thread in the General MKIII category right away.. now it seems that the first thread that needed approval has been moved to the General MKIII category, so that can pretty much just get deleted now.
-I've just done my engine swap, and haven't got a driveshaft yet.. so when I start the engine now I have to have the clutch in.. so I basically can't go out from the car to check the engine when I start the engine.. if I have gearbox oil in then I can move about checking out the engine, as I won't need to keep the clutch in.
Satan
Tampa
There is a Toyota Special Service Tool (SST) that is available to plug it with. Dunno that I'd go through ordering it and all that. I'd just work on other stuff while you wait for the driveshaft, to do this step.
I made one with the yoke from an old driveshaft. Make dropping the tranny a clean job.
