felpro hg..!
Status
Not open for further replies.
rocketman
57
md
I have a Felpro Headgasket with copper seal with a machines and ported head .Then i have arp hardware .Headbolts are torqued to factor specs . I wana know could this set up handle 300hp
zdatsupra
69
florida
I know people who have used them for up to 18 psi of boost.
Im running one now but have not turned up the boost yet. I had a mhg which started seeping water after a year. Since I didnt want to pull the block for better prep I just went with the felpro. Im gonna use it and think of it as a fuse. If I detonate Id much rather blow an easy to replace headgasket vs a much harder and expensive to replace piston.
This is something I think is overlooked when people consider which headgasket system to use.
rocketman
57
md
Ty u guys one other Question.
Is it hard to pull down the oil pan i wana clean the bottom end with some brake clean
8,898
Hard is relative. You have to hang the engine, and lower the subframe.
I bought a Fel-Pro steel core laminate headgasket from Summit Racing just the other day. And the truth is, I don't even know what it is. If it is stock replacement, then it is going in. If it is a MLS permatorque, it will have to wait.
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Your safe, i was on a upgraded fuel system this felpro gasket and arp stud and a t70 turbo pushin 24 psi for about a year and a half and thats what the gasket looked like after i pulled the motor out (reason.. forged internals) itl handle over 400 hp well tuned :)
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
When you say the bolts are torqued to factor spec, do you mean the Toyota factory spec? Or ARP spec? There's a big difference between the two and you should tell us right away cuz if it's Toyotas spec, you need to tighten them more or you'll blow that HG.
Status
