FCD ??
Suprizm2
Boost'n
Oct 19, 2007
Los Angeles
Does anyone know or have a diagram picture on how to install a Fuel Cut Defender on a 7MGTE harness pre-89 I would really appreciate the help! I just removed mine cause some wires were just hanging out unplugged
7M-fanatic
95
San Antonio, TX
The HKS type-K or type-standard ?
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
It just fools the stock ECU into thinking there is less air coming in then what there is. It will make it run lean and probably mess with timing.
FC is there for a reason. If you want be able to run more boost, going LEX and 550s its the easiest way to go.
