Engine Noise Need Help ASAP
yask4it
7m nut!!!
Oct 14, 2006
23
north carolina
OK well was checkin my fuel pressure today and started my car up sand gave it some gas and when I need I heard a load raddle when i let out of the gas. it also does it when i shut the engine off.. I got under the car to listent for the noise and it is comin from up front lower on the engine.. When giving it gas it makes a noise like the noise of a water pump bushing gone bad but it isn't the water pump.... I am think it is the oil pump drive pushing... Do guys think I am correct.. I am trying to make sure that is what it is befor I tear it down and that not be the problem... Any help would be great....
Thanks guys
cuel
1,536
Baytown, Texas
I had the washer break off the front of the timing belt drive gear on mine, and made rattling noises like you described.
