Engine loping....
LordLo
242
OR
Installed one of those Ebay manifolds with a T61 and now the supra has a slight loping at idle.... is this normal? Certainly sounds different from my old stock setup. The rpm is stable however, it just sounds like one cylinder is stronger then the other.
MmMmMmMmMm....
Before it was more like
MMMMMMMMMM
Compression is 160 psi. The engine runs strong and there is more low end power for some reason.
