My speedometer cable is broken, I hit a tree limb on the road and it pushed the sheathing up against my downpipe, which cooked the grease and seized the cable and well... *snap*.
My cable is sort of in the way of my downpipe anyway, so I was thinking about doing a conversion to an electronic speedometer. I have a VSS from a newer model A340E soarer trans, I'm pretty sure it will fit into my W58. The signal from that would go to my JZZ30 Soarer ECU and then supply a signal to the gauge. The only issue is I don't know if there's an electronic speedometer head that will fit into the stock cluster. I don't want to use an autometer speedometer or something. I'd like to keep the stock gauge faces.
Does anyone know if the gauge stepper unit from a MKIV or a newer toyota has the same sweep and will bolt into our cluster?
