electric fans
big idealist
drifter at heart
Oct 23, 2006
135
lowry city, missouri
ok... so i dunno if i should keep the lil 2 fans that are electric and mount up on top of each other on the side of the radiator... dunno what they are called if someone could tell me... thanks... but im going electric fan or fans... and if i go dual fan set up... then ill need to get rid of them... would that be a bad thing? what would happen if i did get rid of them? thanks
cuel
1,536
Baytown, Texas
Those 2 little fans are the cooling fans for the a/c condenser. They help cool the freon, which helps your a/c blow colder.
turbotrev
Goin WEEEEE on my gsxr600
Aug 7, 2006
311
Clinton, MO
come to PHX youll shure use it then biatch! lol
i think they might come on if the engine temp. gets really high but im not to forsure about that.
big idealist
drifter at heart
Oct 23, 2006
135
to be honest i think cuel is the only right one here... cuz really doesnt kick on at any random temp of my car... but when i had it running and turned the a/c on... it came on in less than a minute... and i barely use a/c... but if i took them off do you think a/c would still work? just not as good prolly...
turbotrev
Aug 7, 2006
311
Clinton, MO
for one you can't cool refrigerent(other know as freon) you extract the heat from the freon.
also as i said "I Think" not saying it will! (on the temp. subject)
anywho YES the a/c will work b/c its not dependent on those fans. Those fans are a precautionary thing so the engine will not over heat b/c of the a/c load.
big idealist
drifter at heart
Oct 23, 2006
135
im just gonna go to a salvage yard and get a couple of dual fans... and wire them up to a switch... prolly gonna get some outta van or a taurus or somethin... im gonna measure it all up and shit so i know they fit... oh and if anybody needs stock clutch fan with the 7 blade fan... or the little twin electric fans... pm me for prices... cuz they are now for sale haha
cuel
1,536
Baytown, Texas
lol. Try the fans off of a 98 Contour. Has a low speed resistor that you can use on a temp. switch for the motor, and full speed that you can hook up to the a/c high pressure switch(which is what the 2 little fans are hooked up to). They have they're own shroud, which covers over 95% of the radiator. Takes a little modding, but its pretty easy. Make sure you get the harness for the fans when you get them, and seal the shroud to the radiator.
big idealist
drifter at heart
Oct 23, 2006
135
i got a switch and wiring and shit... so im not to electrical smart... so im not gonna fuck with temperature switch or speed switch... just gonna wire it all up to a switch with one speed... thanks anyway
