im finishing my na-t build realy its a 7mgte with na pistons and block but i removed the egr and im looking for the value of the resistor i need to keep the ecu form throwing the egr temp code. i belive from what ive seen it is 1k ohms. i just need to know if this is correct
also i have read all the threads warning of detonation and now that i am a higher compression motor which makes me more likely to detonate im getting kinda nervous, besides running high grade fuel what else can i do to moniter to make sure im not detonating. setup is stock turbo and electronics going to be ran on stock boost until a stand alone or maft pro installed
