So for all the wiring people out there, i have a question for you. There is a wire shoved in the wiper fuse in the fuse panel and then spliced using a scotch lock into the EFI MAIN RELAY(COIL) wire right before the ecu. My question is what is this doing? What sort of problem is being covered up by this? Im not sure if this is the cause of some of the issues im having like high idle once in awhile,wanting to stall,and the CEL sometimes wont come on with the key in the on position, but it still needs to be addressed. Any thoughts will be greatly appreciated! Thank you!
